Use this procedure to view the QoS ingress port-rate limit statistics. The system displays the statistics of the dropped packets and bytes.
This procedure applies to VSP 4900 Series only.
Switch:1# show interfaces gigabitethernet statistics rate-limiting 1/1
QOS Interface Ingress Rate-Limiting Stats
PORT DROPPING DROPPING DROPPING DROPPING
PKTS RATE BYTES RATE PKTS BYTES
1/1 9224 9260507 1430758 1436481032
Use the data in the following table to use the show interfaces gigabitethernet statistics rate-limiting command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
